Overriding Your Feed Rate When Cutting Around Corners
1964
The following toolpaths now include the Override Arc Feed Rate option on the Arc/Filter Tolerances page.
Dynamic Contour
Peel Mill
Model Chamfer
Override Arc Feed Rate increases and decreases the arc feed rate when cutting around corners. The base feed rate is set on the Tool page.
Max ID decrease sets the maximum feed rate decrease for movement around inside arcs as a percentage or an exact feed rate. Max OD increase sets the maximum feed rate increase for movement around outside arcs as a percentage or an exact feed rate.
