Reversing the Cut Order
2775
The Expand inside to outside parameter has been renamed to Reverse cut order to better explain the functionality. The parameter has been renamed for the following toolpaths:
Equal Scallop
3D Scallop
Surface Finish Scallop
Surface Finish Leftover
Surface Finish Shallow
Reverse cut order starts the toolpath in the center of the part and cuts towards the outside. When you have Reverse cut order and Curves selected for Equal Scallop or 3D Scallop, the toolpath is instead created toward the curves. If Reverse cut order is deselected, the toolpaths behave normally and are created outward using the curves as a starting point.
