Outputting Feed Moves and Fitting Arc Moves
5439
Model Chamfer and Dynamic Contour toolpaths now include the Arc fit maximum radius and Output feed move options on the Linking Parameters page. Previously, this option was available to other 2D toolpaths.
Arc fit maximum radius attempts to fit 90-degree arc moves into rapid and clearance moves. If the entered radius does not fit, then the output creates a 180-degree arc.
Output feed move outputs all rapid moves between passes as a feed rate move instead of a rapid move. This is helpful when the tool needs to make irregular moves per pass to jump between different areas of the part.
