Machining Angle Controls
5474
Listed below are enhancements made to the Multiaxis Unified Plane toolpath.
For Mastercam 2024, the Machining Angles controls are now available on the majority of plane cut pattern options. The angles offered for adjustment correspond to the plane style choice.
This is the Multiaxis Toolpath-Unified window indicating "Machining Angle Controls".
New Machine Angle Controls Supported Plane Types
  • WCS Z
  • WCS XY
  • Construction Plane Z
  • Construction Plane XY
  • Tool Plane Z
  • Tool Plane XY
  • Custom Angles
Enabling Straighten cuts on boundaries avoids rolling effects when the machining surface is wider than the drive curve or when cuts are in the shadow of a hole or the construction of the machining surface. The setting mimics the Extend edge curve option available for other cut types and reduces wrinkling or rippling to produce a more uniform pattern across the extents of the selected geometry.
This image has a dialog box with "Straighten cuts on boundaries" indicated.
