Enhancements to Variable Depth of Cut for Lathe Rough
4374
Lathe Rough toolpaths now let you adjust the depth at the start of the cut by up to 100% of its calculated value. Previously the adjustment was limited to 25%. This lets you vary the point that the surface contacts the tool insert to prevent notching and to improve tool life. This results in an angled cut:
  • A value of 100% means that the cut will be twice as deep at the end of the pass.
  • A value of -100% collapses the cut, resulting in an effective cut depth of 0.
The Variable depth option.
The adjustment is applied to alternate passes, meaning that your cutting passes will alternate between straight and angled cuts. However, in flat areas, a straight cut will be made instead of an angled cut. If the cut length is less than the cut depth, a straight cut will be made instead of an angled cut.
All cutting pass types are supported, as well as ID, OD, face, back, and angled cuts.
