Controlling the Cutting Direction with Deburr 5-Axis
2813
This feature lets you control the cutting direction (climb or conventional) for 5-axis deburring. You can now use the Cut Pattern page’s Direction parameter (first image following) with the Tool Axis Control page’s 5-axis Machining type (second image following). This means you can now control the cutting direction for all machining types defined on the Tool Axis Control page. Previously, the Cut Pattern page’s Direction parameter was only available for the 3 axis and 4 axis (rotary) options.
Note that the Direction parameter is only available when you set Cut with to Flank/Taper.
