Save or Load Defaults in the Drafting and Note Function Panels
3222
With Mastercam 2025 you can easily change your note and dimension defaults without opening the System Configuration dialog box or leaving the graphics window. Click the new Save Defaults button at the top of the Note and Drafting function panels to save your modifications to corresponding settings in the active system configuration file. The next time you open the panel your newly saved settings will be displayed, regardless of whether it is the same Mastercam session.
Additionally, if you are not satisfied with your modifications, the Load Defaults button pulls the system defaults back into the panel no matter how many changes you make.
