Create Multiple Nesting Reports with Unique Names
3761
Sometimes it’s important to compare nesting strategies to see which would work best for your setup. However, in previous versions of Mastercam this required the extra step of renaming the XML in the ActiveReports Selection dialog box, or copying and renaming the file after you generated it. In this new version, Mastercam generates a unique, randomly named XML file each time you run a Nesting report eliminating this extra step.
These XML files are saved by default to your Shared Mastercam 2025commonreportsXML directory. You can rename the files to suit your needs.
Unique and randomly-generated file names in the Common, Reports, XML folder.
