Setup Sheet XML Tags Added
2304
Mastercam 2025 features many new XML tags (see the following table) that you can use to create setup sheets. For more information on the new tags, please refer to the “Setup Sheet XML Outline and Tag Glossary Overview” topic in Mastercam Help. Click the ROOT LAYOUT link in that topic to view the top-level XML tags. The links on the right side of the ROOT LAYOUT topic let you dig deeper into the XML tag structure. To find a specific tag and its description, enter the tag name into the Search bar and press [Enter].
New Tags New Tags
STOCK-LH-OD-PART POCKET-ROUGH-SMOOTHING-RADIUS
STOCK-LH-ID-PART POCKET-FINISH-FEEDRATE-ACTIVE
STOCK-LH-LENGTH-PART POCKET-FINISH-FEEDRATE
STOCK-RH-OD-PART POCKET-FINISH-OUTER-BOUNDARY-ACTIVE
STOCK-RH-ID-PART POCKET-FINISH-START-FINISH-PASS-ACTIVE
STOCK-RH-LENGTH-PART POCKET-FINISH-KEEP-TOOL-DOWN-ACTIVE
MATERIAL-ISOGROUP
POCKET-FINISH-OPTIMIZE-COMP-ACTIVE
MATERIAL-DENSITY
POCKET-FINISH-MACHINE-FINISH-DEPTH-ACTIVE
MATERIAL-HARDNESS
POCKET-FINISH-MACHINE-FINISH-ALL-ACTIVE
MATERIAL-HARDNESS-UNIT-INDEX
POCKET-FINISH-THIN-WALL-ACTIVE
CONTOUR-INTERNAL-CORNER-RADIUS
POCKET-FINISH-THIN-WALL-PASSES
CONTOUR-EXTERNAL-CORNER-RADIUS
POCKET-FINISH-MACHINING-DIRECTION-TYPE
CONTOUR-MAX-DEPTH-VARIANCE
SURFACE-STOCK-TO-LEAVE-CHK
CONTOUR-TYPE
POCKET-ROUGH-DETECT-UNDERCUTS-ACTIVE
CONTOUR-CHAMFER-WIDTH
POCKET-ROUGH-MACHINING-DIRECTION-TYPE
CONTOUR-CHAMFER-TOP-OFFSET
POCKET-ROUGH-ENTRY-ACTIVE
CONTOUR-CHAMFER-DEPTH
POCKET-ROUGH-ENTRY-TYPE
CONTOUR-CHAMFER-BOTTOM-OFFSET
POCKET-ROUGH-ENTRY-POINT-ACTIVE
CONTOUR-RAMP-TYPE
POCKET-ROUGH-PLUNGE-OUTSIDE-ACTIVE
CONTOUR-RAMP-ANGLE
POCKET-ROUGH-ALIGN-PLUNGE-ACTIVE
CONTOUR-RAMP-DEPTH
POCKET-ROUGH-ACTIVE
CONTOUR-RAMP-ONEWAY-ACTIVE
POCKET-ROUGH-CUT-METHOD-TYPE
CONTOUR-RAMP-FINAL-DEPTH-ACTIVE
POCKET-ROUGH-STEPOVER-PERCENT
CONTOUR-RAMP-LINEARIZE-HELIX-ACTIVE
POCKET-ROUGH-STEPOVER-TYPE
CONTOUR-RAMP-LINEAR-TOLERANCE
POCKET-ROUGH-STEPOVER-DISTANCE
CONTOUR-REMACHINE-REMAINING-STOCK-ROUGH
POCKET-ROUGH-STEPOVER-ANGLE
CONTOUR-REMACHINE-REMAINING-STOCK-ROUGH-DIA
POCKET-ROUGH-MINIMIZE-TOOLBURIAL-ACTIVE
CONTOUR-REMACHINE-CLEARANCE-PERCENT
POCKET-ROUGH-SPIRAL-OUT-ACTIVE
POCKET-ROUGH-USE-QUICK-ZIGZAG
CONTOUR-REMACHINE-REMACHINING-TOLERANCE-PERCENT
POCKET-FINISH-ACTIVE
POCKET-FINISH-PASSES
CONTOUR-REMACHINE-DISPLAY-STOCK-ACTIVE
POCKET-FINISH-SPACING
CONTOUR-OSCILLATE-TYPE
POCKET-FINISH-SPRING-PASSES
CONTOUR-OSCILLATE-DEPTH
POCKET-FINISH-COMP-TYPE
CONTOUR-OSCILLATE-DISTANCE
SURFACE-ROUGH-FLOWLINE-CHECK-GOUGE-ACTIVE
POCKET-MACHINING-DIRECTION-TYPE
SURFACE-ROUGH-FLOWLINE-CUT-CONTROL-DISTANCE
POCKET-CUT-METHOD-TYPE
POCKET-FINISH-SPINDLE-SPEED-ACTIVE
POCKET-OVERLAP-PERCENT
POCKET-OVERLAP
POCKET-FINISH-CONTAINMENT-BOUNDARY-ACTIVE
POCKET-START-DISTANCE
SURFACE-ROUGH-FLOWLINE-SCALLOP-HEIGHT
POCKET-EXIT-DISTANCE
SURFACE-ROUGH-FLOWLINE-ALLOW-NEGATIVE-Z-ACTIVE
POCKET-STOCK-ABOVE-ISLANDS
SURFACE-ROUGH-FLOWLINE-CUT-CONTROL-DISTANCE-ACTIVE
POCKET-REMACHINE-REMAINING-STOCK-ROUGH
SURFACE-ROUGH-FLOWLINE-CUT-STEPOVER-DISTANCE-ACTIVE
POCKET-REMACHINE-REMAINING-STOCK-ROUGH-DIA
SURFACE-ROUGH-FLOWLINE-SINGLE-ROW-ONLY-ACTIVE
POCKET-REMACHINE-CLEARANCE-PERCENT
SURFACE-ROUGH-FLOWLINE-RESOLUTION-PERCENT
POCKET-REMACHINE-APPLY-ROUGH-ACTIVE
SURFACE-ROUGH-FLOWLINE-RIB-CUT-ACTIVE
POCKET-REMACHINE-MACHINE-FINISH-ACTIVE
SURFACE-FINISH-FLOWLINE-CUT-CONTROL-DISTANCE-ACTIVE
POCKET-REMACHINE-DISPLAY-STOCK-ACTIVE
SURFACE-ROUGH-FLOWLINE-PLUNGE-CONTROL-TYPE
SURFACE-FINISH-FLOWLINE-CHECK-GOUGE-ACTIVE
SURFACE-ROUGH-FLOWLINE-CUT-METHOD-TYPE
SURFACE-FINISH-FLOWLINE-CUT-STEPOVER-DISTANCE-ACTIVE
POCKET-OPEN-CUT-ACTIVE
POCKET-CLOSED-CHAINS-ACTIVE
SURFACE-FINISH-FLOWLINE-SCALLOP-HEIGHT
OPTIROUGH-CUT-METHOD-TYPE
SURFACE-FINISH-FLOWLINE-CUT-METHOD-TYPE
OPTIROUGH-CONVENTIONAL-FEEDRATE-PERCENT
SURFACE-FINISH-FLOWLINE-SINGLE-ROW-ONLY-ACTIVE
OPTIROUGH-OPTIMIZE-STEPUPS-TYPE
SURFACE-FINISH-FLOWLINE-RIB-CUT-ACTIVE
OPTIROUGH-OPTIMIZE-STEPDOWNS-TYPE
SURFACE-FINISH-FLOWLINE-RESOLUTION-PERCENT
OPTIROUGH-STEPOVER-PERCENT
STOCK-TO-LEAVE-SHARPCORNERS-ACTIVE
OPTIROUGH-STEPOVER
NAME*
OPTIROUGH-ANGLE
NAME-INSERT*
OPTIROUGH-MAXIMIZE-ENGAGEMENT-ACTIVE
MACHINE-TOOL-LOCATOR-TYPE**
OPTIROUGH-STEPDOWN-PERCENT
LATHE-ROTARY-AXIS-CONTOUR-TURNING-TOOL-AXIS-CONTROL
OPTIROUGH-STEPDOWN
LATHE-ROTARY-AXIS-CONTOUR-TURNING-TOOL-ANGLE-LIMIT-MIN
OPTIROUGH-UNIFORM-STEPDOWNS-ACTIVE
LATHE-ROTARY-AXIS-CONTOUR-TURNING-TOOL-ANGLE-LIMIT-MAX
OPTIROUGH-STEPUP-ACTIVE
LATHE-ROTARY-AXIS-CONTOUR-TURNING-TOOL-ANGLE-CONTROL-ACTIVE
OPTIROUGH-STEPUP-PERCENT
LATHE-ROTARY-AXIS-CONTOUR-TURNING-TOOL-ANGLE-CONTROL-LEADING-EDGE
OPTIROUGH-STEPUP
LATHE-ROTARY-AXIS-CONTOUR-TURNING-TOOL-ANGLE-CONTROL-TRAILING-EDGE
OPTIROUGH-MILL-VERTICAL-WALLS-ACTIVE
LATHE-ROTARY-AXIS-CONTOUR-TURNING-TOOL-ANGLE-CONTROL-FAN-DISTANCE
OPTIROUGH-MINIMUM-TOOLPATH-RADIUS-PERCENT
REFERENCE_POINT_APPROACH_X
REFERENCE_POINT_APPROACH_Y
SURFACE-ROUGH-FLOWLINE-ALLOW-POSITIVE-Z-ACTIVE
REFERENCE_POINT_APPROACH_Z
POCKET-ROUGH-ANGLE
REFERENCE_POINT_RETRACT_X
POCKET-ROUGH-REMACHINING-OVERLAP-PERCENT
REFERENCE_POINT_RETRACT_Z
POCKET-ROUGH-REMACHINING-TOL
POCKET-ROUGH-LOOP-RADIUS
POCKET-ROUGH-TROCHOIDAL-METHOD-TYPE
POCKET-ROUGH-LOOP-SPACING
* Added to Drill
** For Turret or Spindle
