Y-axis Turning
4482
Mastercam 2025 introduces Mill-Turn support for Y-axis turning. All turning toolpaths except custom thread and B-axis contour turning support Y-axis functionality.
This image shows Mill-Turn support for Y-axis.
Support for Y-axis turning begins with the tool definition. Tools that can be used for Y-axis turning are identified in the tool definition. A new property has been added to the holder definition which identifies it as a Y-axis tool.
The new Y-axis option for tool holders.
  • Select the Y-axis option when creating a new tool, then continue defining the tool and assembly as you would with other tools. This is the only setting that specifically pertains to Y-axis tools.
  • You cannot edit an existing tool definition to select this option. The Y-axis option is only available when creating a new tool.
  • Y-axis turning is only supported for 3D tools. You cannot create wireframe or parametric tool definitions for Y-axis turning.
When creating Y-axis tools, you will rely heavily on some tool assembly options that are not often used with traditional tools.
  • Typically, you will need to use the Offset feature in the Setup page to make sure that the cutting plane is in the correct position.
    Offsetting the insert's cutting plane.
  • On the Boundary page, adjust the boundary so that the holder profile does not completely obscure the insert boundary.
    Adjusting the tool assembly boundary.
To create a Y-axis turning operation, select a turning operation and then select a Y-axis tool. Y-axis tools are identified in the interface with a distinctive icon.
The icon which identifies Y-axis tools.
Mastercam automatically creates a set of planes that you can use to create your toolpath with the proper tool orientation and spindle origin. It also locks the B axis to the 90-degree position; this is required for Y-axis turning.
The new planes created for Y-axis tools.
When you select a Y-axis tool, Mastercam updates the interface so that it references Y and Z coordinates, instead of X and Z.
Fields labeled Y instead of X.
Use the Tool Angle dialog box to set the angular orientation of the tool. For most traditional X-axis tools, only the 0-degree and 180-degree orientations are used, but for Y-axis tools the Other field will be used frequently. Use it to orient the tool to any desired angular position that the machine is capable of.
Setting the A-axis angle for tool orientation.
Reference point and reference position functionality have been enhanced to support the Y-axis tool orientation. Coordinate positions in all three axes can now be specified for reference points, not just X and Z.
Setting the reference point coordinates.
In addition, the available approach and retract strategies have been enhanced to include Y-first strategies:
Selecting the Y-axis approach strategy.
Some machines that are capable of Y-axis turning do not support CSS during Y-axis turning. If your machine does not support CSS for Y-axis turning, Mastercam will approximate the CSS by incrementing the spindle speed in steps as the diameter changes.
Support for Y-axis turning is limited to .machine files that include the proper components and other settings. If you are using Mill-Turn .machine files that were not created in Mastercam 2025, your Mastercam Reseller or machine developer must enable this support. This is true even if your .machine file includes the proper axis components; migrating the .machine file to Mastercam 2025 is not sufficient. However, the generic Fanuc .machine files installed with Mastercam have the required support enabled.
NOTE:
Y-axis turning is supported in Mill-Turn only, not Lathe.
