Support for Saving and Loading Parameters in Turning Toolpaths
2241
Turning toolpaths for both Lathe and Mill-Turn now can save and load toolpath parameters using toolbar buttons:
The Toolpath defaults menu options.
  • Click the left button to save the current toolpath settings to the defaults file (*.mcam-defaults).
  • Click the right button to open the Load Toolpath Settings panel, which lets you select the source of the settings to load—either the defaults file (*.mcam-defaults) or an operations library (*.mcam-operations) that you select.
    The Load Toolpath Settings panel.
Click the arrow next to the right button to display the flyout menu for quick access to the current libraries.
Displaying the available operations
  • Select Toolpath defaults to load the toolpath settings from the active defaults file.
  • The other options list the available toolpaths in the current operations library (*.mcam-operations). Select the desired toolpath from the list to load its settings.
These buttons replace the context menu options that were used in earlier versions of Mastercam. These are no longer available.
