Set a Default Planes Work Offset
2392
You can now set a default Planes work offset in your configuration. To do this, go to the Planes page of the System Configuration dialog box, and change the Planes work offset setting to Manual. You can then type an offset into the box to the right of the Manual button. Note that the new default offset will apply only to newly created operations; it will not change the work offset for existing operations.
