Verify Selection Enhancements
1152
Mastercam 2027 has featured multiple enhancements to the Verify Selection function. Given the position of the cursor, support has been added for selecting visible AutoCursor positions. In the image below, you can cycle through the available wireframe, solid edges, and AutoCursor positions. In the image below, you can see both the Gview Origin and the Cplane Origin available for selection.
The Verify Selection displays Gview and Cplane Origin.
When presented, Verify Selection displays the list of AutoCursor positions as follows:
  • Temporary Midpoints
  • Point
  • Endpoint
  • Midpoint
  • Arc Center
  • Mesh Vertices
  • Origin
  • Quadrant
  • Intersection
Verify Selection now lets you use interactive on-screen controls, such as the Dynamic Gnomon, while cycling through the Verify Selection choices.
In the example below, using the Dynamic function on the Transform tab command, you can adjust one Endpoint (29.16) and an arc center (1.24) directly using the Dynamic Gnomon during Verify Selection.
The Endpoint displays 29.16 degrees.
The Arc Center displays 1.24 degrees.
