System Configuration Enhancements
Listed below are enhancements made to the System Configuration dialog box.
Updated Screen and Spin Controls Pages
For Mastercam 2024:
The Screen page has been changed to accommodate the new Gview cube settings.
The Wire settings option group that was on the Screen page has been moved to the Toolpaths page.
The Spin Control page has been renamed to General and now also contains the MRU options group, which used to reside on the Screen page.
Setting Import and Export Options
The Converters page in the System Configuration dialog box has been split into two separate pages, one for import options and one for export options. In addition, the Import page contains two new options for handling GDML files.
Unblank Parent Surfaces Option
Unblank parent surfaces is a new option on the Solids page of the System Configuration dialog box. This option is selected by default. When you select the option, only user-defined, blanked surfaces are available to display (Unblank). Trimmed surfaces will not be available.
